I have a impala and driving on my way home suddenly the dashboard breake light went on togheter with the break light fluid level low too, I checked fluid level is ok, break pads ok, front and rear,parking break working well, so I have no idea what is wrong, by the way I purged the four weels, any ideas.
There is a little float in the brake fluid reservoir that triggers the light. Check it’s wiring closely…If you bled the brakes, you may need to re-center the proportioning valve which triggers the “brake” light…A service manual is helpful for these projects…
What year Impala? How many miles?
fluid level can be very tricky to check. Some reservoirs are extremely finicky about fluid levels. Check again.
2005 impala 75 000
