I have an 03 Discovery, and when I turn on the dash lights almost everything lights up except the controls/switches for the heat/cooling/vent control. The LED display light comes on and one of the two temperature adjustment switches comes on. Other than that, all the other switches do not illuminate. I looked at another Discovery and all the switches light up fine on that one. If anyone knows anything about this problem, please let me know. Thanks.
This is usually a matter of taking things apart to find the problem. It involves testing all the wiring connections. Often the problem is a poor ground. It may be as simple as burned out light. The problem is removing the dash is a time consuming job.
How long have you had your Discovery and how long has it had this problem?Thanks for the reply. I have had it for a year and it has been like that since
I got it. It is a livable problem, but if it is an easy fix then it would be nice to have it working again
