MY AC SOAKS THE RUG INSIDE, IT HAS TO BE STOPPED UP, BECAUSE THERE SHOULD BE SOME WATER COMEING OUT THE DRAIN BUT I CAN’T SEEM TO FIND THE DRAIN COULD SOME ONE TELL ME WERE IT IS LOCATED
Please turn off the all caps. It is like shouting on forums. The drain is typically under the dash on the passenger side, under the glove box. You may have to pull back a trim panel and/or the rug to expose it. If you still cannot find it, look under the car at the bottom of the fire wall on the passenger side for a rubber line that is open. You can run a small wire trough this to clear the drain.
