Cruise control
The cruise control lever on my 2008 Scion XD broke off a year ago. Could I have the lever replaced and the cruise control still not work? How much should it cost to replace the cruise control lever?
The steering wheel mounted lever must be what you’re talking about. The wire too? If it’s still hanging there, can you turn the cruise control on but not engage it? If so, it will probably work again. If not, it might still work. You will have to check with the dealer for the cost of the part. Installation may be easy if you’re lucky.
