Crossover AUV towing AWD va Fwd
Front the Highlander owners manual;
If the gross trailer weight is over 2000 lb. (907 kg), a sway control
device with sufficient capacity is required.
You can view Toyota owners manuals online;
http://www.toyota.com/owners/
So your contradicting yourself. First you’re saying it can’t tow 2000lbs now you’re saying it can.
I believe the tow ratings are legitimate, why do you guys believe AWD is necessary? If the front wheel drive and AWD Highlanders are rated to tow 5000# they should be just as capable.
This is the front wheel drive Highlander towing chart;
*1: These models meet the tow-vehicle trailering requirement of SAE International
per SAE J2807.
*2: The model code is indicated on the Certification Label. (ļ‚®P. 639)
*3: Without a towing package
*4: With a towing package
Toyota 5000lbs may say towing with fwd may be fine. But I’ve towed enough over the past 40 years to know I’d never do it. No way no how.
yes, pulling the boat out of the water on a steep boat launch ramp will be tricky. If you have a wet surface, or sandy surface you will have traction issues. The front wheels are ā€œunloadedā€ due to the trailer tongue weight. In general FWD is not good for towing. For pulling a loaded boat up a steep launch ramp, it is even worse.
