My '96 Honda Accord started smoking from under the hood as I pulled into my garage today. Upon closer inspection it seems like it was steam, not smoke, and it came from a crack in what I assume was some portion of my coolant line. The crack is in a solid, plastic tube that runs right along the fore-most part of the car, right along where the latch to unlock the hood. There is an escape valve that warns not to open it while the engine is hot because of the coolant that will be under pressure, hence the supposition that it is leaking heated coolant.
Obviously this needs to be fixed. So I have a few questions.
What could have caused the crack?
Is there a way to repair the crack without replacing the part?
How serious if this / How far can I get away with driving?
Edit: Apparently it’s a crack in the radiator. Same questions apply.
