Corolla 2012 makes sound
Corolla 2012
Miles 94k
No engine lights or warnings and no known issues Except
When i slow down and then press gas pedal to speed up makes a sound Crrrr Crrr comes from around the driver side. Also the sound comes when i normally turn steering at low speed and then press gas pedal a bit suddenly makes this brief sound Grrr. I can produce this problem most of time. What seems problem?
Thanks
Yasir
Check the CV joints on the axle shafts for wear and looseness. While you are there, make sure the brake pads are not worn out and check the wheel bearings for looseness…it might be the very early signs of worn out bearings.
Also check the tires for any weird tread patterns developing. Another idea, a small leak in the exhaust system might do this.
