not getting power to the coil
WOW…that has to be the shortest question yet.
Year/Make/Model would be very helpful.
Yup.
Oh, and how do you KNOW you’re not getting power to the coil?
Run a fused wire, straight from the battery, to the ignition coil. Better?
Can’t do that. You must step the voltage down to the coil once the engine starts. Otherwise it’ll burn up the secondary ignition components. That’s why there must be a ballast resistor/wire to the coil, or an ignition module to step the voltage down to the coil once the engine starts.
