I have had everything related to the clutch changed, and I even had a dealership bleed the clutch line. The problem is the clutch pedal is soft and will sometimes work good and sometimes won’t. If I prop the pedal to the floor for a few hours, it works fine for the day. what gives?
You need to take the vehicle back to the dealership to have them look over the installation and the bleeding of the clutch master cylinder and slave cylinder. Hopefully…they changed the clutch master cylinder and slave as a set. They missed something somewhere.
