On the 17th of this month, I submitted a question about my truck clutch.Maybe I am dense but how is it that the clutch pedal can feel like it has the resistance that it is supposed to have, or at least it seems that way, ans still have no clutch? Is it possible that a rod or shaft going the the throwout bearing broke thereby leaving that feeling that it should engage? I can not help but feel that there may be some hope for this truck yet. Rick
If your truck won’t move the clutch disk is worn out.
The resistance you feel in the clutch pedal has very little to do with the clutch disk, it comes from pushing against a spring or springs in the pressure plate.
OK, so I’m not as dense as I thought, thank you very much for your response.
