i replaced the master and slave cylinder and filled reservoir. i am still slowly leaking fluid every other day or so. where could the leak be coming from? i do not see any fluid leaking on the pavement or in the floor board
So what you’re saying is, you replaced these components to solve this original problem?
Yes. Still leaking clutch fluid
Then you have to look at the link between the master cylinder to the slave cylinder.
If there’s a leak under hydraulic pressure, it can escape as a mist.
I’ll give it a look and update. Thank you
