Clunking in front end of 2010 Toyota Camry at high speeds, even in neutral
My Camry started making a clunking sound up towards the front end recently. It’s hard to pinpoint where the sound is coming from, but if I am holding the shift lever I can feel it. It’s pretty much right beneath the center console / shift lever. It sounds like if you put a rock in a plastic bucket and shook it around intermittently. It started on the highway going over 60mph, but recently it started happening if I am going towards 50mph, leading me to think that the problem is getting worse. This happens even if I shift the car into neutral. Would love to get some information on this before I take it to a shop.
Have someone check if there’s a loose exhaust heat shield in that area.
