I recently had the pads, rotors and calipers replaced on both rear wheels. Shortly after the repair I noticed a clicking sound when braking and found the passenger side rear wheel is offset. I know I need rear shocks and I was told that this is what is causing it to be uneven. My question is will I damage the new parts driving until I can fix the shocks? It will be about a week before I can them fixed
Well, if you are not sure it could cause damage to your new brakes, don’t drive it until you fix your suspension.
