Check engine message
My 2003 Volvo S60 with 68,000 miles has a “check engine” message since Sunday. The scanner at Autozone revealed a P2227 and P0106 error. There is some hesitation when starting the engine but otherwise the car runs fine and gets good mileage. I’m afraid my dealer will say I need a new MAP sensor. Should I try fuel-injection cleaner?
You could try cleaning it with a cleaner labeled sensor safe.
You should try cleaning the MAP sensor. There is a product to do that, which I’ve recommended often enough that people are going to guess that I either invented it or own stock. www.crcindustries.com/auto/content/prod_detail.aspx?S=Y&PN=05110 ? Cached page
