Check engine code P0106 VW Jetta SE 2.5L engine should this be dealer cost?
Took my car to the dealer for a check engine light, the code came back P0106 which states I need my throttle valve cleaned and the dealer also said I need my brake vacuum pump replaced… Do these go hand in hand? How should I proceed with the dealer? I have only 60,000 miles on my vehicle was there a recall on this issue? The dealer already updated the software in the technical bulletin.
The code indicates a problem with Manifold/Barometric pressure sensor.
This isn’t covered under the emission warranty.
This emission component is covered for only 2 years/24,000 miles from the time of sale.
Here’s more info on the code. Most likely cause is a faulty/dirty MAP (manifold absolute pressure) sensor.
http://www.obd-codes.com/p0106
The brake vacuum pump has nothing to do with this code. If your brakes are working properly there may be nothing at all wrong with the pump. I suspect the dealer is looking for problems that don’t exist. But if you are concerned, at least get a second opinion elsewhere. Do not let the dealer fleece you.
