I own 1992 Toyota Camry, 3VZ-FE V6 engine; the code obtained from diagnostic code ouput is #28 which is not shown in the Haynes Repair Manual for Toyota Camry, 1992 thru 1996 models. I thought it was something malfunction which gave me a strange code for coding #28 is unavailable in the Manual, I decoded it by removing the 15A Efi fuse but the Check Engine Light kept coming back. After three times obtaining the code and then decode, the Check Engine Light is coming back again. I give up and post you this question. By the way, the car is running fine, thanks.
Code #28 is for the No. 2 oxygen sensor, but I don’t know which sensor that refers to.
Find all codes for your Camry over here: http://www.troublecodes.net/Toyota/.
