It takes three drive cycles with out a DTC to turn off the check engine light. If you haven’t done the three complete cycles, have patience. If it doesn’t go out after three drive cycles, then get the code(s) read and report them back here.
It is remotely possible that you knocked a vacuum line or a connector loose or something.
