Does getting your tires balanced also require an alignment?
No. New tires cost several hundred dollars. Keeping your vehicle aligned…means the tires will last longer. So it’s good to get an alignment every now and then.
My front left CV axle was leaking so I replaced both front CV axles.
I took it back to firestone and asked if I need a new alignment. They said no because the tie-rods, although disconnected from the control arm, were not removed and that the adjustment was in the tie-rods.
But I think they had to disconnect the steering knuckle from the strut to get the axle out, so I think it definitely it affects the wheel toe/camber.
Is firestone right? Also, a little bit of the transmission fluid leaked out when the mechanic removed the front axles…do I need to put that back in? The mechanic said no need.
I’d have them check the alignment. That’s quick to do and should be less expensive than doing an alignment. And they certainly should check the transmission fluid level.
If the old tires wore evenly and lasted as long as I expected them to and there are no driving issues, then I would recommend against getting an alignment. There is the risk that the alignment tech will do more damage than good.
As for the axles, typically they remove either the tie rods, the strut, or the lower ball joint from the steering knuckle, but only one of them, not two or all three. So if they disconnected the tie rods, then they did not disconnect the struts. And the mechanic was correct in this case.
