I have a 2002 chrysler pt cruiser. For the past week when I start to crank it it will just click one or two times then crank. Today it won’t start at all just clicking. Any suggestions on things I could check or could it just be the starter?
How old is the battery?
If you can get it running with a jump-start, take it to an auto parts store and have both the battery and the charging system tested.
Check your battery connections, connections at the grounding point and at the starter to make sure they are all clean and tight. Clicking of the solenoid is usually a sign of a weak battery or poor connection.
