Engine light came on, turned off my car and now my car won’t start again. When I put the key in the ignition and turned it over, its nothing-no lights, no clicking. Thought the problem might be a dead battery. Tried to jump start. No luck. Took the key out, heard a strange sound coming from around the engine, somewhere between and squeal and a violin.
Sounds like a bad battery. You can’t jumpstart a bad battery with another car because it wont take a charge. Removing the battery on your van is pretty easy. Make sure the key is removed from ignition. Take it to the Zone and have them test it for you.
