92 tercel will not start. Replaced plugs, wires, rotor, cap. Turns over o.k.
You’ll have to determine whether you have a fuel delivery or spark problem. Squirt some starter fluid into the air intake and see whether it wants to start. Report back.
Do a compression test. 142psi is the minimum acceptable value.
Do you have spark? Hook up a spark tester and you should see a bright blue spark.
Take off the valve cover and make sure the camshaft’s rotating when you crank it over. If not, your timing belt probably disintegrated.
