anyone have any tips to get my 97 plymouth neon to stop overheating? please? im desperate over here.
check to see if your water level is on the max mark?if thats ok,it could be a faulty thermostat,or a faulty radiator cooling fan,or at worst a blown head gasket.
Some more information on when it’s overheating would be helpful. Does it do so all the time, only while moving on the road, only while stopped, etc? Do you have to add coolant a lot? Any visible external leaks or smoke from the tailpipe?
There are many causes of a car overheating. This car is also known for having headgasket problems.
