I  HAVE  A 98  GRAND AM  WITH A 2.4 LITER
 ENGINE AND A AUTOMATIC TRANS.AFTER  STARTING
 THE ENGINE  AND PUTTING  IT IN DRIVE THE ENGINE  WILL  DIE UNLESS  I  STEP ON THE ACCELERATOR  HARD. ALSO  STOPPING AT  TRAFFIC
 LIGHTS SOMETIMES  IT DIES  BUT  IT DOES RESTART RIGHT AWAY. I  HAVE HAD A NEW  FUEL FILTER PUT ON BUT THAT  DID  NOT HELP. WHAT
 DO YUOU THINK  THE PROBLEM COULD BE?
Sounds like the torque convertor lockup solenoid is not unlocking.
Does it go into gear with a bang??
If you have a good/independant transmission shop close by, thats the place to take it.
Intake air leak would be my guess. Check for loose hoses and the like around the throttle body. IAC valve maybe another candidate.
