I have a 2000 F-350, 2 Wheel Drive that I installed a 2 inch leveling kit on.
I took it to be aligned, and of course it needs a camber adjustment kit. But here’s my question…
My wheels camber are 2.2 degrees, and 2.8 degrees.
When I go to order a camber kit… I see some that say “0 through 3 degrees” and some say “-3 through 0 degrees”, others are -1 through 2, etc.
Would I want one that is -3 degrees to bring it down to 0, OR are they saying "This is a kit for a vehicle with camber UP TO 3 degrees… so if it’s 3 degree camber, you’d want a 3 degree kit?
One place told me to not do a camber kit, but drop the I-Beams 2 inches and that would align the front end naturally… but I haven’t seen anything for dropping I beams ONLY 2 inches, I’ve only seen 3 inches and up.
Thanks!
