Cadillac sts 2006 problems
I have a cadillac STS 2006. My car all week has been giving me trouble recognizing my key ( it has that keyless entery)and i have to put my key right up to the start button for the car to start. Two days ago my car would not start so i got a jump start car started right up for the next two day just fine until this morning. The car again would not start so I got a jump start and took it to oriley’s to have the battery checked and the alternator. the battery was at zero and the alternator was running a little bit low but not low enough to have to be replaced. i took the car home and did not purchase the new battery just yet. I did some stuff around the house and than went back to the car to see if it would start. it started right up. I did this several times with time in betweeen each try. Car is not giving me any problems now. I am feeling like the problem is not my battery but something electrical. What do you think could be the problem? 2006 V6 cadillac STS
You need to be more specific to get a meaningful answer.
What are the DC and AC battery voltages with the engine at fast idle and all accessories off?
Should be ~14VDC and less then 1VAC.
There could be a “parasitic load” draining the battery,Any decent auto-electric shop will be able to cure this in a hurry…
