Won't start
I have replaced the battery, and start relay. Sometimes it starts like a new car. Other times nothing. All the lights and radio work, no sound from engine when you turn the key.
@Alanita
Put it in neutral and try again
If that doesn’t work . . .
Use a voltmeter to check if the starter is getting voltage when you put the key in start position
If you are are seeing the appropriate voltage at the starter at the appropriate time, the starter is bad
What kind of car is this?
2001 Cadillac STS
Thank you
@Alanita
Thank you
Where is the starter located?
Hopefully NOT under the intake manifold?
I can’t see it. So probably under the manifold.
I was wondering about the security system. Sometimes I lock it and unlock it and it cranks. But not always.
@Analita
When it won’t start . . . is the antitheft lamp on or flashing?
Does the key have a little black piece with a metal strip in it? If it does the resistor in the key could have changed value and is causing it not to start.
I believe it is flashing.
And I don’t see a black strip on the key, going to buy a battery for remote. What have I got to loose.
@Alanita
Good luck
BTW . . . I believe you may have a problem with the passlock sensor
Only a GM or an enhanced aftermarket scan tool will retrieve body control module codes your car
Thank you!
Thanks everyone!
So far so good, I replaced the battery in the keyless entry! Praying it continues to crank.
