My mechanic told me that my boots are broken in the front axles and that I will need to change both front axles for $795 because you cannot tell when the boots where broken and don’t know if the joints are still good and it could make the car stop or make one/both of the wheels seize up while driving.
$795 sounds kind of pricey. I would get a second opinion.
Most people don’t replace the boots. It is often easier and cheaper just to replace the CV axles than replace the boots.
Thank you. I will get a second opinion on this.
For reference, we just had both front axles replaced on an '05 Ford Escape due to bad ABS rings. Cost about $470.
