i just changed pads and roters now the car will not move like something is holding it back it seems to only come from the driverside and i now notice that when i tightened the lugnuts that wheel was not moving
It sounds like a caliper is hung up. Take the brakes off again and see if anything not put on right.
thanks for the response i did remove it with no lucknext i will remove everything and see if the hub turns ?
Make sure you didn’t mount a caliper with a twist in the brake hose. That will cause either dragging or locking of the caliper.
