Is it possible to bleed the brake system of an ABS vehicles w/o a power bleeder and/or scan tool to cyle the ABS? A have a home-brew vacuum bleeder, but not a power bleeder.
I’ve bench-bled the master cylinder, but I think there is still air in the ABS unit.
The vehicle in question is a 97 Chrysler Town and Country with 4-wheel ABS.
Thanks!
Josh
[b]If there’s air in the ABS unit, you’ll need a scan tool to bleed the brakes.
Bleed the base brakes in a sequence recommended by the manufacturer.
Connect the scan tool, and command the ABS controller to go into the bleed mode.
Bleed the base brakes again.
That’s it!
Tester[/b]
Thanks for the reply!
I’ve been meaning to buy a scan tool anyway, so I guess this is a good exscuse
I’ve bled brakes in my '97 expedition before usinga length of tubing into a baby food jar, and a partner pumping the brakes w/ no problems. I now have a vacuum gun that works great. Piece o pie.
I don’t think just any engine scan tool will scan a Chrysler ABS system. Mr. Tester?
[b]You’re going to need a scan tool for ABS systems. A regular OBDII scan tool won’t access the ABS controller. ABS scan tools are not cheap!
Tester[/b]
