my car is leaking fluid from the right front side. I have no idea what it is.
Place a piece of white paper under the vehicle and then report back to us on the color of the fluid on the paper. Until you tell us the color of the fluid and can be more specific than “right front side”, it is extremely difficult to help you.
Looking at the white paper, it appears to be clear, like water. It’s to the inside of the right front tire.
Possibly condensation from the AC.
even if I didn’t have it on?
Another clear fluid is the brake fluid.
Wet your finger tips with the fluid you found on the paper. If it is not slightly oily it likely is A/C condensation.
If the fluid is running down the inside of the tire, it may be brake fluid from a damaged/deteriorated brake line.
It is not oily or running down the inside of the tire. thank you very much, i was worried whether it was safe to drive it.
