Bad vivbes
2004 Pilot, high milage. A very bad vibration which you feel and hear. Bad tire wear inside of tires, especially passenger side. Changed tires and had it algined at one place and checked at another. Still viberating. However, it all pretty much disappears on a sweeping right hand turn, once you turn the wheel about 1/3 of the way. No dif if you turn left. Any ideas?
When was the last time the rear differential fluid was serviced?
The differentials in the Honda Pilots are well known for making noise or causing a vibration when the differential fluid begins to break down.
Thanks, I’ll try it.-lgjon99
