My arir conditioner gives off a bad smell;  my son, who lives distant and is a mechanic, told me that if the drain gets plugged that will cause a moldy  (or other) buildup.  When he visited, he said he could not locate the drain hose.  Where can I find out where the drain hose is?  Then I could probably  unplug it myself.
It is a 2007 HHR SW.  This model was not listed in the model list below.
Thanks for any advice, Merilee… 206 225 1124
              I bet your a/c smells like mold. Have someone remove the cabin air filter. With the blower on high shoot an entire cam of Lysol into the opening. Then install a new cabin filter, that should fix it.
Also, I hope thats not your phome # listed. For safety sake don’t post stuff like that here. There are plenty of spooks, nuts, creepers and wierdos around.
              I am no help with the specific location of your drain hose, but on a six year old car with a cabin air filter, I would not expect the drain to be clogged.  If the car has been wrecked, it may be crimped, which might explain why it is hard to find.
I use Lysol myself to control mold in the A/C evaporator fins, but it that does not do the trick, there are stronger products made specifically for this purpose.  Wurth makes an aerosol spray that you use like Lysol.  I understand that shops use a strong hydrogen peroxide solution, but you have to use that carefully because of its corrosive and bleaching properties.
              @Merilee
I agree with meaneyedcatz regarding the number.
You can EDIT your post and delete those numbers if necessary.  Look for the black icon which looks like a gear just after the title of your thread.  Mouse over that for “options” then click, you should see “edit”.
