I need to find how to replace the rear bearing on a 06 chev aveo. Steve
try you tube. depending on your vehicle, the bearings are usually not difficult to replace. Often times you just replace the hub assembly, so you are just swapping parts. Patience with rusted nuts and you should be ok. again you tube is your friend.
Remove the tire/wheel.
Remove the brake drum.
Unstake the axle nut.
Remove the axle nut.
Remove the hub/bearing assembly.
Installation is the reverse of removal.
