I haven’t seen a “club” in years
As others have already said, if somebody REALLY wants your car, they’re going to get it, and even if it requires a flatbed truck, as I mentioned in a different post several days ago
But if the low-lifes are simply looking for a joyride or a car to smoke reefer in, they’ll probably pass up the car with the club, in favor of something easier . . . aka quicker . . . to steal
At work a few years ago, my supervisor told me to check out one our fleet’s stakebed trucks, which had just been recovered after having been stolen. The thieves were not caught. The truck was found across town, from where it’s usually located.
The thieves had punched out the driver’s door lock cylinder and tore out the ignition lock cylinder. They obviously started it with a flat-tip screwdriver . . . because it was STILL in the truck, lying on the floorboards
I was actually able to reuse the door lock cylinder. It was the plastic exterior door handle which was damaged, because the plastic hole where the door lock cylinder goes through was buggered up.
No other damage was evident. I racked the truck, inspected the fluids, brakes, tires, etc. I took it for a ride. Everything was normal
I suspect somebody simply needed the truck to move some stuff around.
So I ordered an ignition lock cylinder, which I had to code. As I said, that was a few years ago, and it’s still being used regularly. You can’t tell it was ever broken into and stolen
