Just to be clear, you are adding refrigerant to the low side with the top of the can pointed up? This is the proper way to do it, but when working with the little cans, they get very cold very fast which drops the pressure in the can to the point that it will be lower than the low side of the compressor and it will stop filling.
One trick I use is to have a pan of HOT water at the ready and when the can gets really cold, put it into the pan of hot water. That will warm up the refrigerant and increase the pressure in the can so it flows into the system.
I think the numbers you are getting are good numbers indicating that the compressor is working, but you are just low on refrigerant. If you simply can’t add any more refrigerant, it may be that you have a pressure relief valve in the high side and it is blowing off refrigerant at 170 psi instead of the pressure it is supposed to blow off at.
