my 2006 azera keeps blowing the air/cond fuse in the fuse box under the hood.it blows as soon as I turn it on.
You, or someone else, is going to have to trace the wiring in the AC circuit and figure if there’s a short circuit or which component is drawing too much current.
The fuse is doing its job protecting the wiring. There is a problem, but the fuse is not it. The fuse is just the warning device. You, or your mechanic, has to find and repair the problem.
