2008 Buick Lucerne, transmission is slipping, can it be adjusted in frame ?
No adjustments are possible on this transmission, as far as I know. You might try changing the fluid and filter to see if that takes care of the problem but at 10 years old and ??? miles (you didn’t say) it may be time for a re-build.
