I have an Acura Integra 1997 RS (Non-Vtec) Manual transmission with 120,000 miles on it. When I start the car and try to drive away it will stall within a few blocks if I brake or make a turn. Then, I have to turn the ignition for about 10 seconds to get it to start again. I changed the spark plugs, distributor cap and did an oil change. What could be the problem? It runs fine if I let the car warm up for 5 minutes.
Related topics
| Acura Integra 5 Sp 95 starting problems after short stops | 0 | 492 | March 22, 2009 | |
| Car stalls while mostly cruising and won't start for ten minutes | 41 | 8676 | November 18, 2021 | |
| Morning stalling | 2 | 531 | April 21, 2009 | |
| Balky Acura | 6 | 938 | September 28, 2010 | |
| 1992 Acura Hot Weather Starting Problem | 3 | 639 | September 7, 2009 |
