Everthing else works been checked out its a 2006 it keeps blowing fuse
Which fuse? There is one for the compressor clutch and one for the blower fan. Does the blower fan (ventilation in the car) keep running? Then it’s probably the compressor clutch.
You can test this by unplugging the clutch. You will see the connecting wire running into the compressor near the drive belt. Just unplug it, You won’t get any cooling, but if the fuse doesn’t blow, you’ve found the problem. You can replace the clutch without replacing the compressor–usually not very expensive. Some clutches can be done with basic hand tools, Other require special tools which you might be able to borrow from the auto parts store.
