I have a 96 chrysler concorde. The ac condenser got a whole in it and everything came out of it. How do you remove the condenser? What is the name of the tool to disconnect the tube? I have removed the clip from the ring but can’t disconnect the tube.
I believe the fittings just pull out…Nothing holding it except an O-ring, which you will need to replace…
Your local parts store should have a set of these AC line disconnect tools. http://www.sjdiscounttools.com/lis37000.html Without the tool the line can’t be disconnected.
