The ABS light is on all the time. Brakes operate fine and I would prefer to disable the ABS system, especially on this older vehicle. How can I disable at least the dash light without effecting other systems?
Your ABS is already disabled, as you are well aware. You can finish the job by simply removing the light bulb from the instrument cluster. It is perfectly all right in my book to allow the car to live out the rest of its normal lifespan without a working ABS.
Before removing the bulb, verify your state’s inspection requirements. It won’t matter in some states but others may get finicky about such trivia.
