anti lock abs brakes chatter on 1996 chevy S-10 even when when lightly applying brakes?
Can remove fuse and chatter stops however no abs braking.
Is the ABS red warning light on the dash lite? Does the ABS warning light come on for a few seconds after the ignition is turned on? If the warning light is ‘on’, have the system codes pulled to see if there is a problem.
