I tried to refill my ac with A/C Pro with Leak sealer. It worked for the most part. When I took my car into shop to get the a/c done professionally, I told them about the refill and they said they couldnt do it because of the Leak Sealer, and Id probably have to replace the system to get it out.
Is there a way to remove the Leak Sealer? or anything to do?
The system can be flushed with nitrogen, then refilled. It should be done by an auto air conditioner specialty shop. And also have them fix your leak.
Take the vehicle to an AC shop that knows what they’re doing.
All contaminates can be removed from the AC system using one of these.
But it’s going to cost ya!
