99 Ford Windstar start problems
Today my Windstar would not start, it only start if I press on the accelerator if I let go it will die, I’m thinking gas pump any other suggestions?
If the engine will only start while stepping on the accelerator and stalls as soon as the accelerator is released, there’s a problem with the Idle Air Control valve.
Amazing, I just had this happen to me on my Windstar. It would start and die unless I gave it a little gas and kept it above idle. On mine it was like Tester said my IAC. Easy to replace but a little expensive but it did the trick.
