99 Dodge pu 2wd auto and air 360cu in. Where is the fuel filter located on this truck? gas tank or in line ?Thanks for any help
It’s in the tank,on top of the fuel pump assembly. It’s integrated into the fuel pressure regulator. My Haynes manual states that replacement is needed only when fuel contamination is suspected. The replacement procedure is pretty involved; don’t attempt it without a service manual.
