My Neon needed a water pump. At 204K miles the timing belt should be replaced also. The pump and belt were replaced. The motor started and the car drove about 1000ft. and stopped. There was no more spark. The car was checked to make sure that the timing belt is on correctly. The cam points to top dead center when the #1 cylinder is at peak and the crankshaft is at top dead center. Both marks align. When the key is turned the starter tries to turn but the engine does not spark. Electricity goes to the coil pack. Do you have any thoughts? - See more at: http://community.cartalk.com/discussion/2294684/98-dodge-neon-2-0l-sohc-4-cylinder#latest
Related topics
| 98 Dodge Neon 2.0L SOHC 4 cylinder | 2 | 1030 | October 3, 2013 | |
| 1997 neon 2.0 SOHC | 4 | 604 | May 4, 2010 | |
| Dodge neon | 7 | 870 | September 14, 2010 | |
| 2005 Dodge Neon - Flooded plugs | 5 | 627 | January 25, 2019 | |
| 95 Dodge Neon starts then stops | 2 | 1258 | March 3, 2013 |
