I have 1997 Ford F-150 V6 with a rebuilt engine. Mileage is unknown. I changed the spark plugs & wires, & air filter cause I haven’t done in about a year. I took it to get a smog check and it failed. The HC failed @ 25mph and just passed @ 15 mph. The NO failed @ 15 mph & just barely passed @ 25 mph. The CO passed @ both speeds.
Any advice on what I could do to figure out what the problem is and/or to fix my truck so it will pass smog would be much appreciated. Thanks in advance for any help.
No but there was a trouble code before. P1537 was the code. Sometimes the Engine light would come on & then without me doing anything it would turn off. So about a week or 2 ago I erased the codes and it hasn’t turned on. Since I have erased the code, I have driven the truck well over 200 miles so I believe all the on-board test have reset already.
HC is unburned fuel…Gasoline subjected to no combustion coming out your tailpipe. The usual culprits are:
Misfire
Burned exhaust valve(s)
Incorrect ignition timing
The smog guy hooked up a vacuum pump to the EGR valve and pumped it up to 100 & he said the engine should have turned off. It did not turn off. and when he revved the engine the gauge barely moved.
That MIGHT get you past the test, yes, it probably will…But if the converter was shot, the CO would certainly fail too…You would have trouble passing CO with a dead converter…A FRESH converter will indeed burn off the HC but it will soon overheat in the effort…Do the compression test, even a simple electronic test, that will spot a bad valve…If the electronic test spots a suspect cylinder, then put a pressure gauge on that cylinder to see how bad it is…Anything below 110 psi and you have found your problem…
Do you feel any kind of ignition misfire? A thump or pulse in the exhaust? A vacuum leak can cause this too…or a bad injector…
pass few months i have notice the gas mileage decrease to 9-10 mpg before it was always @ 12-13 mpg. yes caddyman there r issues, do u think its worth fixing?
Another bit of info that is probably important. back in 2009 i took the truck to get an oil change @ the local ez-lube. well they end-up stripping the threads on the oil drain plug & installed a temp plug. I have never removed that plug because i didn’t want to risk not being able to reseal it with an oversized plug or another temp plug. so since that has happened, I have only given it 1 oil & filter change by vacuuming the oil out from the dipstick tube. My thought is that there is a lot of oil build up because of the lack of oil changes. So maybe a seafoam treatment might help clean the system out.
You need to get over the oil pan plug and fix it. Its not hard. Any auto parts store can sell you what you need.
But that doesn’t have you failing emissions.
As Caddyman already suggested - before you do anything else, check the compression. Report back with all 6 numbers in psi. If you have compression issues there is no point in chasing your tail about any of it.
If it has a distributor cap, change it.
You have to pull the EGR and clean out the whole system.
That’s not great, but its not going to be the cause of the high HC - unless you’re burning a lot of oil. How frequently do you have to add oil? Pull your PCV valve and tube and make sure it is all cleaned out and flowing well.
Assume that the NO comes from the EGR issue. That has to be pulled and cleaned.
Then check out the rest of the ignition system - e.g. distributor cap, unless this has coil pack/s.
Pull the vacuum line from your fuel pressure regulator and make sure that the regulator isn’t leaking.
