Just before the start of last winter I bought a 97 Crown Victoria P71 Unmarked Police Interceptor, 4.9L with 118k mi.
Since I have owned it (and I suspect for some time before that) it has had a very loud engine knock. (The previous owner informed me that he had been running a 50/50 mixture of 40 weight oil and Lucas oil since he has owned it)
The first thing I did was a simple tune-up. Plugs, wires, fluids, filters. No change to the knock. (Plugs were the picture-perfect poster boys for a clean burning combustion chamber)
End of the winter (3 months after purchase), A DTC creeps up.
P0402 - EGR Excessive Flow Detected
Don’t think something like that would cause such a noise, but I take the EGR valve off, clean it and test it, and it seems to be working fine. I replace the gasket and the valve.
I went to check my codes today, and I have 3. Not sure how they’re relevant, but I’ll include for completeness sake.
P0141 - HO2S12 Heater Circuit Fault
P1469 - Low A/C Cycling Period
I tried to detect the location of the knock with a stethoscope but it seemed to just be loud everywhere. I could not say whether there was a specific side or specific part where the noise was coming from.
At idle, the knock is low pitched and throaty. I’d estimate 240 knocks per minute at aprox. idle of 850 RPM (About 4 knocks per second). The knock increases in frequency and pitch in time with RPM increases. At RPMs over 2k it sounds like someone is under my hood with an air hammer. When the engine reaches operating temperature, I notice the idle knock is a little louder and higher pitched than when cold.
Other than the knock, I’d never know there was a problem. I get plenty of power, the engine idles and runs smoothly, nothing is skipping or shaking.
The only other oddity I notice, and I’m not sure if it’s related or even abnormal, is that my oil pressure gauge always reads somewhere in the bottom quarter of the safe range.
I’ve never had experience with problems like this and would appreciate if anyone could point me in the right direction here.
