I just had my water pump replaced on my 1996 Lumina 3.1L V6. It is still leaking coolant. I can see coolant coming out directly below the petcock around a rubber seal. Is this an expensive fix? What is that rubber seal called?
Related topics
| '99 Chevy Lumina Radiator Work | 11 | 2055 | August 15, 2017 | |
| Cant find coolant leak | 13 | 450 | April 20, 2008 | |
| Coolant leak near water pump? | 5 | 10778 | April 16, 2018 | |
| Low Cooland light | 0 | 380 | September 4, 2009 | |
| Leaking cooling system | 3 | 519 | August 26, 2007 |
