I have a 94 Toyota Camry 2.2L with 180,000 miles. After the vehicle is warmed up from driving the vehicle makes some odd pulsations or vibrations. This is not felt in the steering wheel bu it can be felt in the gas pedal and the passenger can feel it on the center hump that separates the driver from the passenger at the floor board. Any help would be greatly appreciated.
Thanks, Groovy
You probably already have, but did you check the tires? I had a vibration, ended up I had a warped rim and bad tire - its’ hard to tell with radials sometimes. Hopefully not something worse.
